Bettery Draining so fast even in stamina mode (.205)
axiom1
Hello, i updated my XSP 201 to 205. after that, bettery draning so fast! even in stamina mode. took 47 min to take down 92% from 100% charge.
here is proof
bettery flow :
look, screen wasnt on.
proof of stamina mode on
last night i update my phone. then at 6 am i was in bed and woke up like 10 am. And saw my phone switch off itself due to zero percent charge issue. it was like 4/5 hours to take down 23% to 0 %. stamina mode was always on, data connection was off. this isn't normal, right? look at the battery drain on picture. any valid reason behind that?
36 REPLIES 36
profile.country.RO.title
_alexdon_
You do not have to downgrade,just run in compatibility mode with 7.
alexdon
axiom1
i did repair with SUS, still have same problem. look on the screenshoot, no screen wake but still bettery draining. no effect of stamina mode. please, do domething for me Crying_Face
Tags (1)
axiom1
yes. working
_alexdon_
Wait some more after the repair,restart the device regularly.It should get better.
alexdon
axiom1
bro, its alreay pass 12 hours even more. i did everything. nothing happen. someone says it has problem with wakelock. how to fix that ?
_alexdon_
I think that can be fixed only by rooting.It should pass more than 12 hours,wait a couple of days.
A workaround for wakelock is to set the network mode on GSM only.
alexdon
axiom1
i am on 3G network. is that all about ? switching on 2G network will fixed it ?
_alexdon_
Change it to GSM only and see if there is any difference.
alexdon
Akkush
@alexdon : i have constant battery drain even with the latest .205 update.
at this morning i have rooted my phone and installed a custom ROM. (pureexperience 3.6.5) its beautiful ,clear from bloat and other wares. but this **** drain still here !!!!!
DRAIN IS A HEAVY KERNEL BUG !!!!
and cannot be solved with SUS or other voodoos ! believe me....
chillipade
I have the same problem for the pass 4 days, I just power off my phone and it prompt me to update to .205 version, tried it last nite and till now 12 hours later, my battery is back to normal already......
