Battery lose from 40% to 0% ... that need changer to boot again
i'm using XP for FB and chating, battery about 40%
but something my battery lose to 0%, i cant boot my phone.
then after i pluged the changer that can boot up again.
What will happen if i living out my home?
Can i fix it at service center? i'm living at Bangkok, Thailand.
Nabeel
it's a software problem
Repair your phone and all should be fine
AFter repair do not install task killers, battery savers/defenders etc as only these type of apps harm the battery
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
32 REPLIES 32
Francis
Hello ordinary_man
Yes, this is very strange.
Now let me ask you. if you turn off the phone manually before it shuts off by itself what happens? Does it turn back on if you try to do so? Does it give you a red flashing light?
When you charge does the light start at red and then turns orange?
Please let me know so I can better get an idea on the issue.
Francis.
i never turn off my phone. but sometime if i wanna off then on my phone that can off-on normaly.
that just the first time happen tonight. i'm still monitor.
whan i changing the light start with red then turn to orange.
sorr, i'm not well in english.
Nabeel
Hey there  , have a look at this thread
Thank you, Nabeel
i did it last night, now i'll monitor it and I'll report again in the next few day.
Good day.
Nabeel
Please do remember to post in the news here Slightly_smiling_Face
My Xperia P battery still drop again & again.
What wrong of the hardware or software?
And what should i do?
Can I claim my XP to sony thailand?
(Please click on pic to see full size)
http://upic.me/i/mo/batt-drop.jpg
Nabeel
                  or
