Battery is droping from 11% to 1% in a blink.
AnirudhSharma
hi
I have my xperia s which i am happily using from past 7 months having fully updated to ICS.
A month ago the battery was 20% and it suddenly went down to 0% followed by switching off I charged the mobile and it never happened again. yesterday while I was charging the phone and watching a video on youtube the phone got crashed and switched it iff using power+volume up buttton and then restarted it. When it got crashed the battery was around 81% and when it I switched it on again the battery was 97% and this was whole an incident of 3-4 mins maximum. I was suprised to see that but it was ok I thought It would be fine. But, today when my phone's battery went low to 11%, suddenly in a blink it went down to 1% I was shocked. I switched it off, plugged in the charger, switched it on, uninstalled all the recent apps I installed and cleared up the apps I don't use and then I saw the battery level straight away went from 1% to 11%. I again unplugged the charger and saw what happens next. Again it went straigh down from 11 to 1.. I did the same switch off switch on and charged it. Again 1 to 11%. Please suggest me what to do ?? I am so scared. 😞
Regards
HussainQuadri
Try repair the phone with PC Companion after charging the phone to 100%. It should fix the problem (You might get some % less than 100 after you repair the phone but don't worry, It is the adjusted battery.
6 REPLIES 6
HussainQuadri
AnirudhSharma
How do I repair my phone from PC companion ?? I couldn't find any such option.
HussainQuadri
Just click on "check for update". It will say no update is available and underneath it, it should have the repair my ohone option.
AnirudhSharma
Thanks a lot for the Advice Hussain and it worked. Slightly_smiling_Face
BUT, since I repaired my phone a new problem has raised up. My wifi works for a while and then it stops workig though the phone shows its still connected but the internet won't work. I have checked my modem with a laptop and other mobile its absoulutely fine and sometime the same problem comes with data traffic.
I miss my messages and mails for hours due to this problem. please help !!!
