Arc S slow after ICS update
My Arc S is annoyingly slow after ICS update. Higher quality videos that used to play smoothly are choppy now.
Is there any way to speed up the phone or revert to old OS?
I have tried to use Advanced Task Killer but that does not help.
Regards,
RP
Nabeel
It should improve your performance
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
Nabeel
                  or
