Arc/S LT15i/a -18i/a 2.3.4 build number 4.0.2.A.0.62 (pre-rooted version too)
Xperia Arc LT15i/a & Arc S LT18i/a    2.3.4   build number  4.0.2.A.0.62
LT18i
HW VersionSW VersionRequest TypeDate Certified
A4.0.2.A.0.62ECODec 20, 2011
A4.0.2.A.0.61ECODec 12, 2011
A4.0.2.D.0.4ECODec 2, 2011
A4.0.2.C.0.5ECONov 11, 2011
cePwoo.png [480x854px] ฝากรูป LT15i
A4.0.2.A.0.58ECOOct 21, 2011
A4.0.2.A.0.42ECOOct 7, 2011
A4.0.1.C.0.86ECOOct 4, 2011
A4.0.1.A.0.283ECOSep 16, 2011
43 REPLIES 43
1st Backup everything
2nd follow the steps bellow to flash your phone (remember I'm not responsible if anything happen to your phone and this "might" void your warranty)
3th enjoy
it's useful to have
Sony Update Service (SUS)
download FlashTool
http://forum.xda-developers.com/showthread.php?t=920746
or
http://androxyde.github.com/Flashtool/
and the ftf files here
Xperia Arc LT15a/i
http://forum.xda-developers.com/showthread.php?t=1406589
Xperia Arc LT15a/i Pre-rooted update
http://forum.xda-developers.com/showthread.php?t=1330314
Xperia Arc S LT18a/i
http://forum.xda-developers.com/showthread.php?t=1408142
or
http://xperiadev.wordpress.com/xperia-ftf-firmwares/
or
http://forum.xda-developers.com/showthread.php?t=1477440
Install it and you will see  5 folders
                                   Custom
                                   Drivers
                                   Firmwares
                                   Loaders
                                   X10Flasher_lib
take the firmware to the  "Firmwares" folder
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the back button, then connect the USB) press OK
This is an step by step guide
slimshaddy
Hero
they should have made this for the neo v first... because they are the sufferers..
slimshaddy
Hero
any solved problems in arc..?? wifi issue..?
Contacts
this is how to manually backup your contacts with Google/Gmail
open your phonebook
on your computer
SMS Backup + (SMS/MMS/Call Log)
this app it's great it will sync your SMS/MMS/Call Log with your Gmail
SMS Backup +
Save MMS (MMS)
Save MMS
Call Logs (call logs)
Call Logs
SMS Backup & Restore (SMS)
this is by far the fastest way to backup/restore SMS
Apps
Don't worry so much about backing up your apps
on your computer go to: market.android.com -> log in -> click on My Library -> and send all your apps to your phone
The Backup & Restore was designed for the 2010 Xperias but work with the 2010, 2011 and 2012 Xperias
the Backup & Restore app will backup your SMS, MMS, Call Logs, Settings, Apps & Contacts.
Use one of these links to download the apk
Link 1
or
Link 2
or
Link 3
or
Link 4
or
Link 5
How to sideload apps
unkown sourcess MUST be selected
1st Method
download OI File Manager (or any other file manager)
OI File Manager
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
go to box.com and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
BOX
4th Method
download the app, transfer it to your SD card
Download Apk Manager
Apk Manager
open "Apk Manager" and voila select the apps that you wan't to install
nothing really, it seems that just added Arabic, but nothing important so far
slimshaddy
Hero
hmm..it was supposed to be a issue solver Slightly_smiling_Face
and theres arabic language because its an arabic firmware Winking_Face
