How to move those apps which are always stored in the internal memory to the sd card after gaining root access?
Here you go
http://talk.sonymobile.com/message/142152#142152
Here you go
Also can you help me with this?
I'm not getting the notification toggle+Battery percentage. Its not working i think.
And Cosmic Flow mod also stops wprking as soon as i apply it.
Can u Help..?
I'll look into it but in the mean time read this
http://www.engadget.com/2012/06/18/android-wakelock-api-bugs/
Android apps that use power control APIs are often 'battery killers,' oh the irony
http://www.tgdaily.com/mobility-features/64061-api-glitch-may-explain-fast-draining-phone-batteries
http://www.purdue.edu/newsroom/research/2012/120613HuSmartphoneBugs.html
Thanks man.
poor coded apps, are you running any taskiller and/or antivirus?
yes iam using RAM booster and advanced task killer. No antivirus.
you don't need those apps, uninstall them ASAP
ok then what?
Done...
have you rooted your phone and moved all the apps2SD?
this should improve your performance
