Hello,
after updating to Android 4 the SD is no longer detected as drive with a drive Letter but the Xperia ray is detected as mobile device with the SD card below. Due to this the Navigon Fresh SW don't detect the mobile as Navigon device as it did before. It is now mandatory to switch off the Phone, open it, and put the SD card into a card reader. Now the Navigon fresh detects it as Android phone and Updates can be performed.
Does anybody know how to mount the SD card with drive letter to avoid this?
regards
What USB mode are you using?
Check in this menu, Menu > Settings > Xperia > Connectivity > USB connection mode.
I think you should be running on MSC mode.
Ahh, I'm stupid, you're right the mobile was in MTP mode. Now I remember I did it when I got the phone last year. I never touch this setting again so I forgot it and with the new Android version it was set again to MTP. Works now as expected.
thanks
Thaloss
