After update xperia ion hsdpa to jb it shows LTE preffered
kolithakasun
I want to know is it work?
Alexander1
If you have used none official software update tools it sounds like you have flashed a LTE based firmware to your phone.
LTE will not work in your phone since it's not supported by the hardware.
5 REPLIES 5
Alexander1
How did you update your phone?
Which build number are you running on? Check under settings > about phone > build number.
kolithakasun
6.2.B.0.211 is the build number. I update it from flashtool.
Tags (1)
Alexander1
kolithakasun
Thank you for the help.
Tags (1)
Alexander1
Anytime! Slightly_smiling_Face
