Hello
My phone displays the following error:
Activity Home screen (in application Home screen) is not responding
I cant open the menu or do anything. Any ideas on how to fix? Thanks.
Regards
Danfoss5000
Thank you. I'm not sure if it's ok or not, but i installed launcher pro and the problem seems to be fixed.
its totally ok
its official sony software.. well if you have ound a work around , great
I have updated it with the software you said and it worked but after a week, the same problem occured. Now I don't want to update and get everything erased again so I looked for solutions and one said that the screen brightness was too low, and it was so I go ahead and fix it. It also did work but the problem, again, occured. Any other suggestions?
do you install some application like juice defender , task killer battery saver..??
no..
ok you can backup your files..
how to backup..!!
download any one of the file on your computer . ( if you download this directly on your phone , it will be easy , if not then download on your computer )
http://www.mediafire.com/?78bcyp5alpwy0ok
after downloading it , follow these steps
http://talk.sonyericsson.com/message/130376#130376 from step 2 onwards..
and try this also , this wont delete anything , i havem;t tried but some guy said..
just try t after backing up ok..
1. Open PC Companion
2. Start 'Support Zone'
3. Select Software Updates
4. Click on Repair
Looks like this file isn't available any more
which file are you taling about ? the one marked as correct ? here's the new link , i will edit above as well
http://www.sonymobile.com/global-en/tools/update-service
are you facing a similar issue ?
Me on my SE account this time... I hadn't realised the link was for the Android update, thought it may be a specific patch. But thanks for the change anyway.
I am using an Xperia Active, and leaving an app and going back to the homescreen is just a nightmare when the phone has been on for a while. If it does load it, it will take 2 or 3 minutes, more likely I will get a force-close. The same feedback came out of reviews of the mini/active home screen when it was first leaked, but I kind of hoped it would be fixed when it came out on the actual devices
I am using Go Launcher now, which seems to work a little better - I don't like loading my already distressed phone with yet more bloat, but it does actually mean I can use it - I miss my little corner pockets though!
Michael.
