3G not working on Xperia S after upgrade to 6.2.B.1.96
Goran74
Just did the update today and found out that 3G is not working. There are network lines but no connecition to the Net. WiFi is working OK.
I tried to switch off, switch on, disable - unable data connection, no luck.
I am in Croatia.
settings > xperia > internet settings
13 REPLIES 13
Bearings
Try looking for your service provider's Access Point Netwrok on the net and set it to the latest. If problem still persist, you likely need to reinstall the software. Use SUS for a clean installation.
Goran74
Fixed! Thanks a lot for help!
abelito
I had the same problem, how do you fixed it?
pa1reddyp
go with the solution provided by Uliwooly(the 3rd message)
abelito
I have already done that but nothing happens when i choose "OK" option Slightly_frowning_Face .
pa1reddyp
You need to manually create access points. Try to get help from your cellular customer support.
abelito
Fixed! Thank you so much! Grinning_Face
Don't forget to give kudos Face_with_stuck-out_Tongue
