Hi.
for using just one sim card in M dual , is it different to use sim card slot 1 or slot 2 in xperia M dual ? (Isn't it cause damage to device that using just 1 sim card in M dual?)
thanks
I think it wont damage your device. In sim 1 slot it supports 3G and 2G network. In sim 2 slot it only support 2G network
i use 2G network , (my sim card operator is 2G) , so , its better to use it in slot 2 in attention to your commandment that slot 1 is 3G/2G and slot 2 is just 2G .
So i changed to the slot 2 because sim card is 2G . if i buy 3G sim card or my sim card operator bring 3G , i will use slot 1 . thank you
Anytime
hi,
even if it is solved, both slots support wcdma, but only one can be used with wcdma. You could witch this in the settings.
further details:
regard
