Repeat caller on don't disturb problem.
RoozbehM
Hi every one, I have a problem with my M5, when enable repeat callers on Priority only allows is enabled, activating don't disturb with option Priority only, let all calls ring.
Calls= none and Repeat Callers= on , ring for every calls, I tried other states too but when the repeat callers is on every calls ring.
Tried factory reset too.
Android 6.0
Is it bug or it's just my problem?
3 REPLIES 3
CameronT
Hi @RoozbehM, welcome to the community.
This is very strange Thinking_Face Will it do the same thing if your phone is in safe mode?
RoozbehM
Yes problem exist on safe mode too, I found other people that have this problem with their M5, I think It's a bug 30.2.B.1.21 Build for M5.
CameronT
@RoozbehM,
The only thing I can find internally about do not disturb and this build is an error message saying "Unfortunately, System UI has stopped" may appear. This is only when you have your language set as German.
I recommend you run a software repair using Xperia Companion as this will re-install the firmware, just in case there's an issue there. Make sure you back up first.
