Xperia l.purpose of camera button
nishar
I can see a button for camera on the right bottom.. It does my serve any purpose. When I try to click pics wit that, it just gives a sound for click and doesn't actually click any...
DeepanshKhurana
Hello
You must be slightly pressing it that is the focus sound which you mentioned.
Here is how to use the button correctly...
Softly press and hold to focus at this point a white box will change to a slightly blue bordered box and will give a sound.
Now, press it more to click the focused image.
It is a two step process. But once you master it i.e. minimize the shake etc this method gives the best results for photos.
Hope this helps. Slightly_smiling_Face
-Deepansh
If I solved your problem, don't forget to give a kudos. Slightly_smiling_Face
3 REPLIES 3
DeepanshKhurana
Hello
-Deepansh
nishar
Thanks..solved...
chavus
THANKSSSSSSSSSSS U REALLY HELPED ME!   Slightly_smiling_Face
