Hello,
I have a problem - clock doesn't refresh...The clock i left corner is ok, but the clock on the widget doesn't refresh, i have to click it (it moves me to clock aplication and go back, then it refresh).My phone is Xperia L4. Does anybody have this problem?
Which widget?
Hi JQB1988;
Have you tried removing the clock widget and reinstaling it again?
I tried a lot of things, the clock widget doesn't refresh when you don't have any type of lock sreen, when you set a type of lock screen it resolves the clock widget problem. Case closed.
Did you try to test on safe mode ?
