Xperia L users please don't use third party applications that causes your mobile phone into risk. Please download only from the Sony's original apps or apps that can be downloaded from Sony Online Network. Use Power Saver options for battery life, use good network sim, keep checking to close unwanted apps often. Have a happy Xperience with Sony!!!
You should download apps from the Play Store, as for closing apps that's not necessary as this will create issues with Android and drain battery.
The advice should be
"DO NOT BY THIS CRAPPY PHONE BECAUSE SONY DOES NOT GIVE SUPPORT TO YOU FIXING THE BUGS "
