Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Hi @Dvb-des
Ive sent you a private message with some instructions - let me know how you gt on.
Cheers
I gathered it wouldnt work for you in Brazil. Unfortunately it looks like you have a different problem over there
Good luck
Cheers
Hi !!!!! @Anonymous
I received help from a Brazil forum.
"We tried the standard Android TV method (copy and rename the software as upgrade_loader.pkg the same stick , disconnect and reconnect the outlet holding the POWER button on the TV) ?"
Success !!!!
Hi Quinnicus,
I have the same problem on my 55w755 which they exchnanged and it is on PKG2.343EUA firmware. Can you please help me?
Cheers
Hi @hurkale
Ive sent you a private message with some instructions - let me know how you get on.
Cheers
Hello.
I have the same problem on my 43W756C. Can you help me? Thanks.
Hi @taectaec
Ive sent you 2 private messages, one with some instructions and the second one is correcting a mistake i made
Cheers
Thanks, software was upgraded without mistake.
Brilliant - glad it worked.
i have same issue please help?
