New K55XR80PU picture freeze's and sound still playing
Simpsonpaul0
New
My new TV that’s just over a month old has froze twice this weekend, the picture just stops but the sound continues playing. The Tv is then not responsive at all and has to be switched off at the wall.
anyone experienced this or know if there is a fix? Don’t want to have to return the TV 😢
Tags (1)
6 REPLIES 6
EMS_MO72
Community Team
Hey @Simpsonpaul0
Try to follow these steps and test again: Home-Settings-Storage and Reset -Internal storage-Cached data-Enter , and then select yes to remove the cached data , and then soft reset your TV.
george4370
Explorer
My tv is 8 weeks old 55in oled sick fed up of it freezing, only use sky q it’s happened 20 times begging to wish I never purchased it so disappointed can this problem be fixed
SatoruGojo
Community Team
@george4370 Is it the same model in the thread ?
george4370
Explorer
Yes same model as above
SatoruGojo
Community Team
Hey @george4370
Try to follow these steps:
  1. Please remove the cached data:
    1. Press Home
    2. Select Settings
    3. Pick the Storage and Reset section
    4. Select Internal storage
    5. Go to Cached data
    6. Press Enter on remote
    7. Select Yes to remove the cached data.
  2. If it continues, try to reset the TV.
  3. Finally, if the issue stayed the same, perform a factory reset.
Gouron
New
I’m on my second TV as the first one did exactly the same, froze or turned off but only while watching Virgin TiVo on HDMI 1.
I did  a full factory reset on the first one and before I could set everything again it restarted again. The new one has been fine until the last week when it’s frozen 3 times in one day and powered off and on again today.
If it’s cache then surely it’s not doing garbage collections if this is causing some kind of out of memory issue.
it’s the same model as everyone else. Bought from  Currys.
