The volume buttons will only wake up the screen if the phone has not entered sleep mode. When you lock the phone, it will take about 5 seconds before the phone is in sleep mode and then the volume buttons won't wake the screen.
Perhaps it is the quick launch button for the camera that is pressed while you have it in the pocket which is waking the screen. Try to disable it via Camera > Menu button (three dots) > Settings tab (the one with a gear wheel) > Quick launch > Off.
If the flashlight is active, you cannot access the camera. You need therefore, drag down the status field and turn the flashlight off from here.
@Aj8 Brilliant fix, that worked a treat.
This has happened a couple of times to me whilst my handset has been in my pocket. Thanks again.
closest option in setting is 15 sec .... there's not "immidiate" in sleep option
sorry my bad, you meant autolock
