Z5 dual display issues
MikeOr
I have a week old Z5 dual.  The screen has vertical lines going through on the right side and actual display is (for the lack of better word) milky.  At times the horizontal lines appear on the screen.  There is no demage to the phone nor has not been used a lot.
Anyone else have experienced issue like this?
Xperia support was not helpul at all, with the answer given we don't service this phone
10 REPLIES 10
Phy
Legend
Legend
This seems to be a hardware issue, could you boot on safe mode and see if you experience the same issue.
How to boot on safe mode
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Phy
Legend
Legend
you can also repair the phone with PC Companion.
http://support.sonymobile.com/gb/tools/pc-companion/
@MikeOr
I'm sorry to hear that, but it seems like that's a hardware issue, if the phone was purchased in a different country the warranty its only available in that country. Also, if the phone its not available in your country, Sony can't check the phone for the same reason.
John-BR
Hi @MikeOr
Welcome to the community.
I would suggest checking to see if these issues are coming from the hardware of the handset.  We have a build in feature called Xperia Diagnostics to help with this.
  • Go to Settings > About phone > Diagnostics.
  • Tap Test device.
  • Select the tests for the Display.
  • Follow the on-screen instructions.
Could you let us know what the results of that are?
MikeOr
Hi John,
I have tried this.  Under display test is says, screen will turn black then white.  My screen only turns black and then finishes the test.  I didn's see any dead pixles.  All other tests worked fine.
MikeOr
safe mode has the same issue
Vagcon
Anyone can help. I have display problem on my z5 dual Premium. The screen tends to dim or go dark itself. Have shut down battery saving mode and adaptive brightness. Have also reinstall software with pm companion but problem still persist. Screen dim itself
Chinmoy32
I have a Z5 Dual E6683 myself in Bangladesh and have no official warranty. I have checked 3 more phones before i bought this unit and 3 of em had the same problem you described , the white screen has some (2 or 3 bright and subsequent darker horizontal bar types stripes across the screen) problems. Then i bought the 4th one I saw and i had the least of em and thus I have bought it. now using it for like 2 weeks or so I am noticing that the screen is getting darker bar type horizontal areas (3 of em )  from the right side of the screen to the middle of the screen with fading endings. it looks like the screen is getting old or dieing or getting tired at those areas. Its not that prominent when the brightness is at its full or displaying mixed color contents but its kinda noticeable when the display is showing white color or shades. I don't know what to think or what to do here. Worried about a faulty unit or manufacturing faults.
If anyone has any sort of solution or reason behind this please come forward.
butt31316
Same problem here
