The battery can still be charged to 100%, but after short time, the phone turned off itself, despite there's still >70% battery on the indicator.
Using the *#*#7378423#*#* key, i can see that the battery is in need of replacement. Where can I replace the battery? Or should I buy a battery on the Internet then get replaced somewhere?
May i get a price for the replacement?
Thanks
P/s: I'm currently at Muncie, IN, 47306
Hi @lazyOwl,
For that purpose, you should contact your Sony Mobile local support first or visit Xperia Care in your country in order that you get advice what will you do then. If your smartphone battery should be replace with a new one, battery replacement and its services may be charged depend on your warranty status.
Better buy brand new phone than replace ur batery..sometime the technical not profesional..like the phone not water resist after change battery
