Hi @Mwael105,
You can also try enabling USB debugging mode. To do this go to Settings > About Phone, and tap on Build until it says "Developer Mode Activated". You will see a new setting in your settings menu called Developer Options. Go in to here and turn on USB Debugging.
It could be an antivirus/security app.
Hi @Mwael105,
hi i have problem with otg in xperia z3plus e6533 mm253
i do detect usb device but didnt work for me and the cable&flash are safe
help please
It's fine to leave USB Debugging on, you shouldn't notice any difference in how your phone operates otherwise.
