Z3 compact Will not recognize a micro sdhc card?
Rominaschryers
Hallo...
Does anybody know if its normal That my Z3 compact does not recognize a micro sdhc card?
Before i was using a regular micro sd card, and this was never a problem before...
But since That one is almost completely full ( was only 16gb) , i Changed the memory card, to a micro sdhc card of 64 gb.
Problem is, when i insert the card,, i see That my Phone gives a detection of a card, by a notification as a little card That pop's up in top of the screen.... When i remove the card, i also get a warning notification: removed sd card, place New one...
But when i check my storage settings, i can't tap on any option concerning the sdhc card....
I thougt i have read back at That time i ve bought my Phone, the specs were mentioning the Phone was compatible for use micro sd, as well micro sdhc..
Does anybody has any idea?
Thnx
Romina
Tags (1)
@Minaken
What if you reformat the SD card?
5 REPLIES 5
@Minaken
Rominaschryers
I could give it a try, even the card is empty....
I see That know after i took it out and plugged in again,  i can tap the button 'link sd ', which before wasn't even possible to tap on it,  however hé does still not indicatie any more extra gb from the card....
But ill try reformat the card and see what its says...
Thnx... .
@Minaken
keep us updated
Rominaschryers
Whoehoew.... Thnx... You're the hero of the Day... It worked by make the card empty (strange because it was already empty),  but Who cares, it works now!!!
Thnx for your help!!
Spoiler
@Minaken
Excellent, enjoy your Z3
