Z1 Problems
shyams
Z1 Problems
HI
 I bought a z1 recently. I have problem with data download without WIFI. It does not work at all. No data can be accessed.  The twitter page, facebook, mail  etc remain static to  whenevr i have last used it with  last WIFI awailability. I have swithed on and off the phone many times. The 'STAMINA MODE' and 'LOW BATTERY MODE' ia always in OFF position.
I do not know the reasons.Am i missing something? Kindly help
Regards
shyam
Thommo
Genius
Have you downloaded the settings for Data and MMS - Settings then under Xperia Connectivity open More then at the bottom tap on Internet settings then Accept then a list will or should appear - From that list select your provider making sure to select the right one as some providers have two ie: Contract settings and PAYG
3 REPLIES 3
profile.country.RO.title
_alexdon_
So you have problems on mobile data?Did you download internet settings?
alexdon
Thommo
Genius
shyams
Thanks Thommo and ALEXDON.   Thommo sir your solution was perfect and the matter is solved.
Thanks once again
Regards
