Hello everyone.
A week ago I bought the xperia zl phone and I tried to also use the pre installed "Remote Control" App to use the built in Infrared blaster. I can't make it work though. What I did is:
- I manually installed two deviceds (projecter / av receiver).
- Through the remote control software I programmed some keys in holding the original remote of the device in front of the infrared blaster of the ZL. The Remote Control App told me that it 'Learnt the command'. I then saved everything and tried to use the programmed button but both deviced don't react. It seems the infrad signal is not sent out.
- I also tried to hold the infrared blaster of the zl really close to the deviced - still no reaction.
Do I miss something? Does infrared have to be switched on seperately? I checked in the apps and all Remote Control Apps / Service seem to be running.
I did uninstall / disable some sony apps before but I don't think I disabled relevent apps for the remote control to work....
Anyone having the same problem? or a solution
Michael
@coolasrevi : could you send us some picture(screen shot) of manual setup from your new xperia ?
and how about manual setup for air conditioner remote ... it is work ?
thanks
Brand new ZL. Remote works with the build it one for Samsung. Manual learning simply doesn't work. So looks like the unlucky one to get a bad piece. Oh visiting Sony Service center is a nightmare from whatever I have read.
This is the screen shot of Hathaway STB manual setup. didnt try AC yet will let you know soon.
If replacing the unit with a new working box piece is the way to go, perhaps Sony could organize an address that will swap out our IR-incapable units with proper ones? Or perhaps instruct the repair centers to do just that, when they can't find or repair the problem?
*edit*
Blimey, I think Rickard came through! I just got a call from Sony Germany support who's handling the Sony Dutch support (the ZL wasn't released here in NL), who was in turn contacted by Sony Sweden (!).
Anyway, they'll be sending me a document to send in to the German W-Support company to replace my unit with a new one. Hopefully I'll have the same experience as coolasrevi, which could indicate that the IR problem is only an issue with the first batch of phones.
@bouvrie : can you help me ?
how to contact rickard or another staff ? i want to ask about service in indonesia ... is there any replacement for my defective product ... because when i bring my phone to service center ... there no one know about this problem or they don't want to know the issues ... they just suggest to factory reset ... to the first firmware , and isn't work right ?
it still under warranty ..
@coolasrevi : thanks , but could you send us little more detail step by step manual setup by picture(screenshot) , manual setup with air conditioner remote,if you don't mind ... thanks
#anyway sorry for my bad english
@caifull In my case, Rickard from the support staff here at the forum offered to get me proper help with this problem. He asked for a PM with my service case details to find someone in my (local) market who can help fix this.
In my case, it seems to turn out that my local Sony Support will be the best way to get this resolved (even though the Xperia ZL isn't available on my local market).
I think the best thing for you to do, is to contact your local Sony Service, and clearly describe the problem. Be sure to mention that the problem will not go away after a factory reset, firmware update or other software modifications and that Sony officially knows this problem is with the hardware in some Xperia ZL units. You could also point them to this thread, but I doubt that the support people will look into this (mainly English and pretty long) conversation.
As far as I can tell now, from the many users in this thread, only 1 has had the problem solved. (India, Bangalore, Jayanagar Service Center) Although it may still be possible to replace an individual hardware part of the IR, the only solution I've seen documented here is one where the full unit gets replaced. For a replacement unit, Sony has to order the local service center to replace the unit. So to get that in your case, you'll first need to get Sony to acknowledge the problem. And I think this is best done with your local service in Indonesia, also to prevent any miscommunication through a language barrier.
By the way, I can't be sure that a full phone replacement will be the solution for my intended use; Sony Support called me when they offered the phone replaced, and said that even a fully functional phone is not guaranteed to be able to learn IR commands for all devices. However, I have faith that the devices I have at home aren't too freaky and will learn just fine. Either way, I'll keep posting here until my issue is resolved.
Tried number of times with our HATHWAY STB. It simply didn't work.
Moreover, with the free cover that came with the phone, the IR blaster hole isn't there so I am not wasting must time with it.
Don't want to be wasting time with ignorant support staff as before purchasing i tried lot of presales mails wrt this problem and none of them came up with explicit answers. They just kept playing passing the buck game.
I bought ZL as Samsung was not on my list.
In case anyone's interested, I have yet to send in my device for replacement. I'm waiting for Sony to confirm that this time, I'll get a proper new device instead of another faulty unit.
Hello friends! Greetings! Speaking straight from Brazil. I was having the same problem here with my xperia ZQ, ZL there for you. The device reported that learned the sign, but did not seem to give no signal so when taking the test. Then I saw a hint around at some forum. Position the control just below the ON / OFF one centimeter to the left side, almost touching button zq and neighbor. I auditioned with a stereo, one microsystem from LG, which does not appear in the list of factory zq xperia and it worked perfectly with all the buttons I created. It is my contribution.
