Xperia Z2 bootloop help.
Linegod
Can anyone help me?
I've tried to repair the phone using the companion app but the "Your device is locked" always shown.
Is there any way to skip pass this?
Jonas
Hi @Linegod, sorry to hear about your device. Slightly_frowning_Face
You can start the repair when the device is turned off and not connected to your computer, so start with turning it off the device. If it doesn't work when using the power button, you can follow the instructions below.
  1. Detach the cover for the micro SIM card holder.
  2. Using the tip of a pen or a similar object, press and hold down the OFF button.
  3. After your device emits a series of quick vibrations, release the OFF button. The device turns off automatically.
When the device is turned off, make sure that it's not connected to your computer and open up Xperia Companion > click on "Software repair" > check the little box in the bottom left corner > Next and follow the on screen instructions.
Let me know if that helps!
