Xperia Z won't start
abeer04
I tried to update my Sony xperia z C6603 to lolipop through flashtool but it stuck on flashing data.After 2 hours I removed my phone and turned it on but it won't turn on now it say Update failed.Now I downloaded kitkat frimware from xperiafirm and tried to install it again stuck on Checking header.
38 REPLIES 38
@abeer04
Download flashtool and a new FTF file > remove both SD and SIM cards > connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 1 hour > flash the phone either with flashtool or repair the phone with PCC
abeer04
When I press power button and volume up button nothing happens.
@abeer04
Does it vibrate at all? does the LED turn on?
abeer04
@uliwooly
nope no led flashing no viberation my bootloader is not unloacked (maybe that why)
@abeer04
then try this
Connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 3 hours > even if it doesn't seem to be working
abeer04
@uliwooly
Now it viberated once then after a while 3 times and then restart loop sony logo then that update fail error again and again.Should I leave it for 3 hours now o.O
@abeer04
you should.
abeer04
@uliwooly
This restarting for 3 hours is giving me chills is it ok to leave my mobile like this
Spoiler
Face_with_stuck-out_Tongue
It's not ideal, could you try a different cable/charger?
