I have just installed 4.2.2 on my Xperia Z (Netherlands)
When i first start up the phone the bottom bar is transparant as it should be.
Once i press my lock button and unlock it again, i enter my pin code.
The bottom bar is now black as before. How can i fix this?
Rebooting the phone does not help!
Thanks for reading/helping.
Florin
EDIT:
The bar is now always black, even when i start up the phone.
The problem was a wallpaper app, Mine was called something like backgrounds HD.
Just remove the app and reboot the phone fixes this.
Got it from XDA forum btw.
Thanks for helping anyways
Topic viewed 134 times, Not a single response.
Does anybody have an idea how i can fix this?
Try a repair using SUS but back up everything before doing it.. if you are using dark background you wont know if its transperant or not
Try to apply the default theme again. I've read that this is working on some devices. Then, you can change the wallpaper again
