Every so often while using my home wifi on 5g I begin to have a connection problem when the wifi icon goes from white to non white then back to white again indicating the connection is going on and off, I have to switch the phone off completely and this sorts the issue.
Any idea what causes this?
The only thing I can suggest is to repair the phone with XC or keep an eye on which apps are running/open when that happen
Trouble is that when trying the safe mode solution you have to restart the phone which by doing so normally would fix the issue anyway till the next time.
So I wouldn't know which third party app it could be.
Am I correct in thinking that the software repair option using the Xperia Companion I would be required to install all my apps again from playstore?
Yes, this will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
@Quester wrote:Yes, this will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
Thank you.
