Hi to everyone
I wanted to discover opportunity to buy an external AMP for my great headphones, but now, on my Z5, with latest fw.200, I see no more this opportunity
What has changed in this way ?
Hi @Robertods88,
In the Xperia Z5 you have to go to Settings > Device Connection > USB Connectivity, then choose Detect USB device after you have connect the external amp/DAC. It is also possible to add the option to detect USB device to your quick settings.
As long as the external amp/DAC supports Android without the need of any unique drivers this should allow you to output audio via USB.
And on Z3C ? I know I'm OT here but just for knowing ...
Hi-Res audio output works since Z2
In a Z3 Compact you should only need to connect the devices without having to enable any setting or similar.
Many thx, I'll be answering here if everything shouldn't be ok
Let us know if that's the case!
Does anyone know this function still work on Android 6.0 (my phone is xperia Z5)?
I cannot hear any sound when the phone is connected to AT-PHA100 USB DAC using the general music player.
ps, it works by using "USB Audio Player Pro" App to play local songs.
Hi @lindar_tw,
As far as I know the functionality should still be there. Is your phone able to detect the USB DAC when you choose Detect USB device in Settings > Device Connection > USB Connectivity?
