Weak Wi-Fi signal after Android 6.0.1 update
LongDiepVN
In new version of Android 6.0.1 on Xperia Z2 (D6503 Customized NCB_1282-0508), the wifi signal of phone is very very weakly, it very badly on the smartphone. I suggest sony fix it as quickly.
23 REPLIES 23
LongDiepVN
@Blade10X wrote:
Well LongDiep. Mostly it's just the new system, but i hope it will ne resolved with new updates. You can try to use WiFi Signal Booster apps. This could enhance a signal from 30-40% i guess. I tryed it and did notice a little boost. When you are looking for those apps be carefull and choose wisely because most likely 80% of them are pranks only, it's though to find real app for this. Indeed i do know one. Description of this app: It's a deep blue icon with white wifi in the middle and red cross like first aid.
Search by 'WiFi Signal Booster'. Also there is another one called 'Interner Booster & Optimizer'. Red icon with white signal in the middle. This app can be used for both root or non-rooted phones. Give it a go, you might see improvements Slightly_smiling_Face
Thanks Blade10X, I will be try it and choose it as workaround while I waiting new updates.
I very love Sony but now Sony appear many error. Although Sony released new Android is slowest.
I hope sony fix it as quickly.
Aqibsh
After upgraded to MM there is most commonly problem is wifi week signal problem, I'm using same router at same place before MM and after MM,
LongDiepVN
Yeah, as me known, many many people are just like us.
prodigy
Hello everyone. Me too had the same problem after the MM update. The WIFI signal is very poor. I hope that SONY will fix it soon.
Neff
Hi everyone. I have the same problem, but i also have it on my mobile internet. The signal was always poor, but now it's almost nonexistent 😞 it just doesn't work...
decanigher
I do have the same issue. Since update on Marshmallow my wifi is really weak. My version is not a beta 570 but it seems Sony wants us as alpha tester
TommyNation
My Z2 has the same issue, wifi drops VERY often, totally irrelevant of signal strength. Wifi worked flawlessly before MM.
Also the new camera app and removal of the camera widget shortcuts is terrible...
HelgeT
Today I installed the latest update for my Z2. Now I have build-no. 23.5.A.0.575 installed. After the update, the Wifi become useless. It connects to the access point, is getting an IP-address, says, "No Internet connection" (which is not true, because some other devices, connected to the same access point have internet connection), disconnects and starts the procedure again. Before the update today, everything was working without any problems (had there also Android 6.0.1 - don't know the build-number anymore).
Is it possible, to go back to the state, previous to the update today? I'm very unhappy about this situation, because I need the phone with a working Wifi-connection for my job.
Kind regards,
Helge
Bearings
People facing wifi issues, please read this and solution it provides. Sony didn't create Mashmellow, Google did.
Cheers.
How-to-fix-wi-fi-problems-android-6-0-marshmallow/
Xperiaz2_AZE
Any solution for resolving this issue?
