Volume Warning for headphones missing.
mekanix
Xperia Z5 compact.
The warning that usually comes when you try to turn up the volumen to high, have suddenly disappeared from my phone. Don't recall that I have disabled this.
Also, separate volume control for headpone (wired) and bluetooth are missing (don't remember if they have been missing all the time or if that is a feature for Lollipop).
How do I get that warning back?
23 REPLIES 23
TerryQ
Is it possible that a briefest of moments not at full volume, is resetting the 20 hour timer?
Rickard
I checked your customization and it's a nordic unit so it will display a popup warning every 20h when volume is above 85dB.
What headset/headphones are you using?
@TerryQ
I'm not sure if the counter can be reset and it may perhaps also have to do with the headphones used. I will see if i can get more information about it.
mekanix
The headphones is a pair of Sennheiser CX 300-S.
Regarding the 20 hours... there is something in your wording that got me thinking.
These 20 hours, are they cumulative? Ie. if I play at full volume 1 hour each day but at normal volume the rest of the day, it will take 20 days before I see a warning?
Or will it be 20 non-cumulative hours from the moment har exceed the limit. Ie. if I turn the volume to max at 4pm but turn it down shortly after, then at 12 noon the next day a warning will pop up if I try to exceed to limit?
TerryQ
I was thinking any drop from full volume could reset the timer. I have my phone connected to my stereo so I can listen to Spotify, phone volume is at max and stereo volume set as required. After a couple of days like this, I guess it worked out at 10 hours a day, I got my volume warning. Plus it automatically reduces the phone volume, which came as a surprise to me lol. Brand new phone so I don't know all its actions yet 😄
Rickard
The information i currently have doesn't say how these 20 hours are calculated i'm afraid. I've forwarded it internally to see if i can get more information on this.
mekanix
After 2 weeks I can still crank up the volume to max without warning.
TerryQ
I would love the warning not to turn up, gets annoying if you listen thru a stereo and suddenly everything goes quiet 😄
Bandolero
Hi, What you can do is go to your settings > Apps look for SmartConnect. clear the app data and restart the phone.
Now try to turn the volume max again. The caution/warning should show again.
If that don't work, just go to Settings > Apps on the upper right there is 3 little dots. Tap on it and Clear app preferences.
mekanix
Hi
The first solution did not work. And the second solution I do not want to try, wouldn't I have to redo all the settings for all the apps again?
Bandolero
@mekanix wrote:
Hi
Hi, definitely one of this will work. if the first one don't then i can already confirmed the 2nd option will work.
Not all settings will be wipe out or something major will happen. I.e if you disabled an app, after you did the reset. That app will be re-enabled.. thats it.
If you think that this will cause too much hassel. then is up to you to do it. Cheers!
