my phone vibrating not work
i already test with diagnostics tool & use reset factory on my phone
still my phone can't vibrate
anyone have a solution ? :'(
Thx n i can't speak english properly, sorry
hope u can understand my mean
Believe me have tried everything and I mean everything including the stamina mode deactivation, but still no luck in restoring back the vibration function...
Hello, the same problem has just started to occur with my phone... But instead of it not vibrating at all, it chooses random moments to not vibrate for however long until it starts vibrating again. I could be typing with vibration on minute and then the next it doesnt work, same with the three main keys
Try turning off STAMINA MODE. If nothing happens, you have a defected phone
Same problem for me : vibrator seems to work properly once , and when used for a time it finally stops, as if it was heating and then blocked... (for example when I write a text message the keyboard makes it vibrate at the beginning and finally the vibration stops).
I tried factory reset, tried software repair in companion, but still works randomly. It really stops after a while. checked also with Sony Diagnostics App.
I Plan to send it back to Sony Repair Center... (unfortunately garanty ended last month...)
