Vibrating not working
RudzLong
my phone vibrating not work
i already test with diagnostics tool & use reset factory on my phone
still my phone can't vibrate
anyone have a solution ? :'(
Thx n i can't speak english properly, sorry Slightly_frowning_Face
hope u can understand my mean Slightly_smiling_Face
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
26 REPLIES 26
_alexdon_
Have you dropped it or anything like that? You should however take it to a close sony service:
alexdon
lazz39
Hey.
I got the same problem. Whenever i get a text message, my phone doesnt vibrate, nor it doesnt show it on the startscreen.
When i get a phonecall or play a game, the vibrate works without problems. The only vibrate issue is the text messages.
And the funny thing is - before i got the new update "Lollipop", the vibrate of text messages worked perfectly. Now its kinda dead.
_alexdon_
Are notifications enabled? Do you use the default messages app?
alexdon
lazz39
Still nothing happens. The vibrate is activated, but it doesnt vibrate when i receive messages.
_alexdon_
Can you check if the same occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
lazz39
Thank you for the guide. But it seems not to work. My phone stil doesnt vibrate, and it doesnt shows on the startscreen. :(..
_alexdon_
Try settings-apps-all-messages,force stop and clear data. Restart. Take a backup of your messages before.
alexdon
lazz39
Sorry but that doesnt work either Slightly_frowning_Face Jesus, this pisses me off
_alexdon_
alexdon
