I have seen several messages in the forum about this, but in the case of my phone the lines go away when i start using my phone, it almost seems like when the phone heats, thats when they go away, i dont get how can this be a hardware issue when the lines fade away, can i be something else? I already boot in safe mode and its the same behavior
Hi @Matt_Malpica,
Welcome to the community.
I'm sorry to hear this. I recommend that you turn off developer options if you have them enabled. To do so, go to: Settings > Developer options > Off. If you can't find developer options under settings then its already disabled.
If the same behavior persists, I'd recommend that your perform a software repair using Xperia Companion, this is to make sure there is nothing software related causing this behavior.
Let me know how it goes!
Same result
If you are still experiencing the same behavior after doing a software repair, I recommend that you get in contact with your Local support for assistance with having your device sent in to an authorized service center for repair.
