Unknown USB Device (Device descriptor request failed)
Temelj
 Phone no longer wants to connect to a PC (Windows 10) via USB.
Windows Device Manager shows the phone as "Unknown USB Device (Device descriptor request failed)" and the phone does not provide an option to select - charging only, usb file transfer or that third option (MTP).
The Phone does appear to charge via PC USB & normal wall socket genuine charger.
Also, as the battery icon changes to charging - a solid orange led is lit while doing so. But I'm not longer receiving the notification on whether I want to connect my device in File Transfer mode.
Phone has the Android 7.0 update - 32.3.A.0.372
Any help/advice?
PS: Xperia Companion does not detect the phone and cannot be used for a software repair.
UPDATE:
Thanks NeoBeum for the proposed patches to my particular issue.
In summary:
  • Disable "USB selective suspend setting" under "Control Panel\Hardware and Sound\Power Options\Edit Plan Settings" in the Advanced Settings.
  • Uncheck "Allow the computer to turn off this device to save power" option in Device Manager for the "Universal Serial Bus controllers".
I can confirm that in my case the Xperia Z5 connects to the PC, charges from it and displays the popup "Use USB to - charge, transfer or MIDI". I can also confirm that I can debug applications from Visual Studio directly on the device.
However, I do not accept this as a solution as the windows related power settings should not affect the performance and connectivity of the Xperia Z5. These problems do not persist on other tested platforms/devices (Google Pixel, Samsung S5, Apple iPhone) connecting to the exact same computer.
I will try another Xperia Z5 Compact device to try replicate these issues.
55 REPLIES 55
NeoBeum
Enthusiast
You need to make sure the screen doesn't turn off, or the android os will disconnect mtp
NeoBeum
Enthusiast
I'm just showing you some errors that's caused by the software installation partition if it isn't configured correctly.
I was flashing/reflashing/reconnecting/fastbooting my phone this morning while I was testing out Nougat, and I managed to get the error again.
The difficult part is that it won't say SONY Mass Storage - I actually changed it's name, so I could find it faster when these things happen, and also the Class GUID will be different for each machine, just try and find pairs like I have highlighted
NeoBeum
Enthusiast
In total I think the Xperia can have 6 different USB configurations..
Lasch
Hello again!
If anyone has been reading this thread looking for a solution for a similar problem, I just want to tell what has happened to me.
In february I called the Sony support, and they concluded (as NeoBeum earlier) that there was a hardware failure and advised me to send the unit for a warranty repair. Due to some travelling and other activities I haven't sent the phone in until last week. I got it back yesterday. They have changed the mainboard and USB.
Now the telephone works! As far I can see all the problems I had before are fixed.
So, don't forget hardware problems!
I want to thank everybody who has been making efforts to help!
Mukesh3246
You can sole this issue by following these simple steps:
https://thewindowscentral.com/device-descriptor-request-failed/
shoaibameen
Device descriptor request failed is very common error on device for windows users. There are 3 cases for this error. 1- Users see yellow warning sign along with their device error in the device manager but there is no any problem in the working of device. 2- Device is not working properly. The device of these users won’t appear in the File Explorer. So users not able to use it. 3- Device is not working but the status of device is “working properly”.
