I'm unable to establish a connection to my VPN, type L2TP/IPSec PSK using an IPSec pre-shared key (local and external). The VPN is running on a Synology NAS (model DS713+ with DSM 5.1-5022 Update 2).
After configuring it hangs on "Connecting..." and after a while it says "Disconnected". When I look at my VPN server logs, nothing seems to be happening on the server as if nothing tried to connect.
My old LG Optimus 2X running android 2.3.4 is able to connect using exactly the same settings and within the same environment, which makes me quite sure about the Xperia Z1 Compact being the culprit.
Software
14.4.A.0.157
Android
4.4.4
Model
D5503 (unbranded)
Is there a way to debug this on the Z1 Compact? Or is this an known issue? If so, is it going to get fixed?
//EDIT:
Apparently I'm not the only one with this issue on Xperia devices:
H Rickard, I have a z5. my Vpn still doesn't work. My BLE still doesn't connect to certain wearable devices. Any updates since this last post?
There's no update available for Z5 yet fot this i'm afraid.
If you are unable to connect to certain BLE devices, please make sure that you have downloaded and installed to correct host app for those devices.
I have Xperia Z+ and unable to setup ipsec xautn Psk VPN using built-in Vpm app as it disconnect immediately, is there any solution to overcome this issue
Build number
32.3.A.2.33
Android version: 7
