TOUCHSCREEN problem
ravi_sony12
TOUCHSCREEN problem
Apps opens by itself even without touching the phone. Touchscreen works without touching the phone.. Opens anything randomly
3 REPLIES 3
ChloeS
Hi @ravi_sony12
Welcome to the community!
Sorry to hear about that Slightly_frowning_Face
Do you have a screen protector on your phone? If you do, can you remove that, clean the screen and see if you still have the same issue?
If you don't, could you test the phone in safe mode and see if the touch screen is still misbehaving.
Let me know Slightly_smiling_Face
ravi_sony12
I did everything you are saying. I removed my tempered glass, used the phone in safe mode, repaired system software from sony website. But the problem is still there. What else should i do???
ChloeS
Hi @ravi_sony12
Thanks for confirming that.
From here you would need to contact Local support so they can assist further. The handset may need a physical repair which your local support can assist you with.
Good luck Slightly_smiling_Face
