The problem with the speakers
Dato99
The Sony Xperia Z3 compact has two speakers, from where the music plays. The problem is that the top speaker plays louder than the bottom, nothing happened with the phone, the bottom speaker is not dirty. The fact is that in headphones, the phone works on the same system, the left earpiece plays louder than the right, so it happens on the phone. Please tell me how to get rid of this problem.
На устройстве Sony Xperia Z3 compact имеется два динамика, от куда играет музыка. Проблема в том, что верхний динамик играет громче нижнего, ничего с телефоном не случалось, нижний динамик не загрязнен. Дело в том, что и в наушниках, телефон работает по такой же системе, левый наушник играет громче правого, так происходит и на телефоне. Подскажите пожалуйста, как избавиться от такой проблемы.
Rhydz
Have a look at
Settings | Sound & Notifications | Sound Effects | Equalizer
At the bottom of the screen is a slider that controls the balance between left and right channels.  Make sure that the slider is in the central position.
4 REPLIES 4
Rhydz
Have a look at
Dato99
Sliders are installed by default, all at the center
Ползунки установленны по умолчанию, все на центре Screenshot_20180129-214459.png
@Dato99
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Nifta
I have a similar issue, where the top speaker is louder.
The slider bar shown above is for the the 'clear bass' level, not a left/right balance.
I havent found a solution to the speaker balance issue.
