the brightness control not working
intra
Hi .. My Phone screen very low light
when I do unticking the Adapt to lighting conditions box .. but the screen still low light. and when i move the brightness controler nothing happened. and my phone running in low brightness level.
hope to fix this problem.
Note:
I do reset my  phone and repair it with PCC but nothing change.
thanx..
13 REPLIES 13
intra
Hi ..
the brightness control not working and my phone running in low brightness level.
Cheers.:smileygeek:
reset your phone and check again, if not repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Jake-SonyXperia
Hi intra,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Have you tried unticking the Adapt to lighting conditions box when inside the brightness section?
intra
Hi Dear Jake-SonyXperiaSupport .. and thank you for quick support.
yes dear i do unticking the Adapt to lighting conditions box .. but the screen still low light.
intra
thanx dear uliwooly for your answer.
i do that but nothing change.
intra
andrewjc
Hi ,
make a note of when the screen goes dim.
It maybe that you have "power management" settings opting to save power when your battery is at a certain level.
So, try changing your 'low battery mode' settings. and turn the setting OFF.
This should stop the phone trying to conserve power and keep your background light bright!!
PS: also make sure your brightness settings are set accordingly.
See how you go.
Cheers
Queenmheii
I have the same problem :'( please help
