System ui
airscrew
System ui
System ui has stopped comes on every morning at roughly the same time every day. Phone goes blank but after a restart it's fine till the same time the next day. Anyone have any idea why? Thanks.
Tags (2)
2 REPLIES 2
ChloeS
Hi @ronnibrent
Welcome to the community!
Can you check if you have any accessibility settings turned on, if you do turn these off and see if you still have the same problem.
Find and tap Settings > Accessibility > Make sure to turn off every setting, depending on setting, either by tapping the slider, or by first tapping the settings title and then tapping the slider.
Let me know how it goes Slightly_smiling_Face Jack-O-Lantern
SJN1969
I have the same issue. Repaired via Sony Companion (factory reset) about a month ago and seemed ok but now back, everyday at about 11am. Tiresome.
