HI,my Z3 Dual is stoppted suddenly.I connected it to cheger for half hour but it does'nt power on!
Was your phone exposed to water?
you could try again
connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2-3 hours
The last option is to contact your local Xperia care
forgot to mention that battery was 0% before it was dead
I figured, try my suggestion, if it doesn't work then contact your local Xperia Care
when i press power + volume up for 10 sec nothing happen as if i didnt press them is it normal ?
If the battery its fully depleted, nothing will happen. let it charge for few hours as suggested above, the only alternative is to contact your local Xperia Care.
The issue is probably that you allowed your battery to be completely depleted and as a consequence the kernel is now unable to kick in and direct the power to the battery for charging, I wouldn't be surprised that you have a blinking LED when connected to a power source
Nothing you can do - If you were to able remove the battery and charge externally, From experience then I'd say you'd be fine so all you can do is to either return your device to the place of purchase or contact Xperia care and have it inspected http://www.sonymobile.com/global-en/support/contact-us/
