go to settings-storage and look there what occupies most of your memory. you can also tap cache and delete all cache
i hope this helps
I use Astro as I know from my Xperia S days you can choose to show hidden files and folders
@ JadeBaco,
Can you please advise what the figure shows within Storage.
Menu > settings > Storage
Let us know what is using the memory, you should see a colorful bar with a legend below it.
In Astro tap on Multi then select all then delete or select all then tap on files you want to keep to deselect then tap delete
@ JadeBaco,
If you wish to remove the photos faster, I suggest that you connect your handset to a PC and find the DCIM folder with thumbnails and remove them. You can easily scan through folders using a PC.
Are you aware on how to access the internal storage through a PC?
Any time, glad we could help.
Keep us updated.
