Sound in quick settings
N5
Why have Sony removed the sound icon in the quick settings bar? This is very annoying as it was available in the quick settings before the update!! Sony sort it out!!!
profile.country.RO.title
_alexdon_
Now to change sound schemes,you need to press on volume button and after that you can change to silent,priority,vibration.
alexdon
18 REPLIES 18
_alexdon_
alexdon
N5
Thank you.
_alexdon_
Anytime.
alexdon
Bex1
I don't appear to have a vibration setting in the volume control. How do I activate this?
_alexdon_
Just press on volume down until you get to vibration.
alexdon
Bex1
Got it thanks
Nicoleye
Thank you, was frustrated by this!!
si-mungo
New
The absence of the sound quick setting has been mentioned elsewhere in this forum but I'm not satisfied with the proposed solution of using thevolume rocker as this doesnt work if for example the walkman app is running as the volume rocker then only changes the volume of the media that is playing. Please reinstate the sound/vibrate/mute quick setting!
Tags (2)
I agree with you, although you can lower the volume fast if you press the volume key then tap on the bell, it's futile if you are playing music, videos and/or video games.
@Rickard
#BringBacktheVolumeQuickSetting
