can i charge my sony xperia z in laptop for 30 min after unboxing???? no two pin plug in here soo
Yes absolutely fine - You should have a battery metre informing you of the charging status
As long as the output is 5v which it is from a Pc/Laptop then you will be fine but charging will take longer - As for your power plug you will need to contact the place of purchase about this
im gonna keep it more than 30 min then...??its fine to charge on laptop for the 1st time?? i mean dosent make differnce from laptop or power plugin?
yeahhh!!! it has been more than hour been charged...& my notification light has been orange from red...that means>???
Battery notification light status
| Green | The battery charge level is greater than 90% |
| Flashing red | The battery is charging and the battery charge level is less than 15% |
| Orange | The battery is charging and the battery charge level is less than 90% |
