Sony xperia z2 wifi direct not working....
Stunner
I Have tried to send files using wifi direct on my xperia z2 to samsung galaxy note 3.But it only pops up a notification that file transfer failed.I need a solution for this issue...
dm841
disconnect and reconnect on both devices start a fresh connection and make sure no interfernce
12 REPLIES 12
dm841
Stunner
Its working Thank u man..
dm841
Cool anytime
hmoodeh_diabat
i do this  you answer but not working please help me
if you can attach videos for how i can send by using wifi direct i will be geratfull .
iam waiting you answer as soon as possible
Praveen7791
Hey All,
I have same problem too please share pick or video and full discription.
AlmoselhI
wifi direct. It always fail, wifi direct. It always fail, wifi direct. It always fail, wifi direct. It always fail, OMG!!!!!
AlmoselhI
dont work >>>>>>>>plesssssssss help
Tags (1)
medo_h_e
Please help it dosen't work
i think no benefit if WiFi direct without stock app
please fix this issue SONY
Praveen7791
Guys I found the solution for this problem. You need same application both devices to using wifi direct. Like file commander app which is pre install in xperia mobile. For transfer xperia to other mobile, share files commander app to other mobil, now you can able to share files,video to other mobil.
Better option to use wifi transfer, use xender.
Thank you guys
