my phone has stopped after using camera inner sea on a superficial level .i put it in rice for two days then opened the cover and Clear the circts surface with alcohol by brush . i pressed on red botton which next to sim then he worked but for a houre then stopped again . finally i go to Technical whom told me that circts has stopped work and if i want shoud repealce it that cost 3700 EP about 208 $ and that is totally mobile cost .what i have to do sony ?
Hi @ya123
Welcome to the community!
If your handset has sustained water damage it will need to be assessed and repaired by a service centre.
As this is a global forum, the best thing to do would be to discuss this with your Local support who will be able to help you arrange this and direct you to an authorized repair centre.
Good luck
