1- Revise your Smart Connect settings, don't forget that Walkman is now called Music, may be you need to re-select it again.
2- Clear cache of Smart Connect app:
- Go to Settings -> Apps -> Smart Connect -> Force stop, Unistall updates, Clear data.
- Go to your Play Store and update Smart Connect again.
No problem. Why do you add "Pause Music" to your Smart Connect settings anyway? Just keep the settings to start Spotify and delete the part of pausing Music.
May be it was fixed after upgrading to Music app, just try it and check if it works now.
I suggest that you report this issue to Sony directly, may be the incluse it in a future update or fix:
Cheers, glad I could help.
