I think that's idea of pinning, you lock your display on a specific app to be used by a quest/stranger. But after you un-pin it will it take you to the lockscreen or leave your phone unlocked?
Go to Settings -> Security -> Screen pinning, there's an option to enable "Ask for unlock pattern before unpinning"
Sorry for not answering your first question: No, it returns me to the phone unlocked state. As I wrote it in the original post, I did enable the "Ask for unlock pattern before unpinning" option and tried it many different ways, but it still does not ask for password/pattern.
Thanks for the effort anyway, but I'm convinced that this is a bug. Just wanted to make sure.
This is definitely a bug.
It worked correctly on my previous phone under Android 5.1 but my XZ1c is having issues on both 8 and 9.
With Ask for Pin Before Unpinning ON:
1. Pin screen
2. Press power button to disable display
3. Then press power again to turn the screen back on
Expected behaviour:
1. Pinned app is shown
2. When app unpinned phone prompts for pin to continue using device
Actual Behaviour:
1. Phone asks for pin immediately on wake.
2. App can now be used in pinned mode
3. Unpinning app gives full access to device without reprompting for pin.
As it currently is screen pinning is mostly useless for its main use case.
