Screen locks entirely during phone call on Xperia Z1 compact
Tonje
I discovered today that when placing a call the screen locks and I am unable to unlock it again until the call is terminated. If I place a call to a number and want to hang up before I am connected, the screen is just black and the on/off button does not work. I have to wait for the call to terminate to be able to unlock the screen.
If I activate the function of letting the on/off button hang up my calls, then I am able to hang up during a call. However, if I call a customer service type phone where I need to give numeric input (for example provide my customer id number) I am unable to active the screen and use the dialer (number pad).
I have done the following to try to fix the problem:
I resterted the phone.
I have checked that I have the latest available update version for the phone.
I have done a factory data reset.
I have booted the phone in safe mode, and I experience the same problem then.
Help to fix this problem would be highly apprecited.
Tags (2)
Tonje
alexrx - I was not sure what the test is supposed to do.When I clicked on the Proximity Test in the meny I got a black screen that said "Proximity switch ON". It did not change if moving the phone around.
I did not know where the proximity sensor was located - but a little google helped me along. For others who might find this post - it is located in the upper left corner. Having a screen protector covering the sensor I decided to remove that and it seems to work now. So a dirty screen protector seems to have been the root cause of the issue.
Thank you for pointing me in the right direction 😄  (I wish the guy at the Sony support chat had been able to do the same...)
16 REPLIES 16
alexrx
Enthusiast
Hi there,
Can you confirm us that your proximity sensor is working properly?
Dial(phone app) *#*#7378423#*#* > Servise Tests > Proximity Switch (test it).
Cheers.
alexrx
Enthusiast
....Also you can try to repair the phone using Sony Update Service.
Tonje
I did check for updates on the phone - and I believe have the latest version. I am unable to use the PC Companion as I am on a Linux machine (not Windows).
alexrx
Enthusiast
Can you ask a friend for help that using Windows 7?
Tonje
alexrx
Enthusiast
You´re welcome.
I'm glad you found the cause of the problem:smileyhappy:
DulanA
Thanks. you found it +++++
Rose7
So did your problem get rectified after doing this? Did u really have to pull out the screen protector on that part... If im not wrong is that sensor just towards the left side of the front camera? Please help
Rose7
I did that test it says proximity switch ON.. Btw I use Sony xperia z ultra
