Hello during a call the screen of the smartphone goes blank impossible to answer the call what to do?
Здравствуйте во время вызова гаснет экран смартфона невозможно ответить на вызов что делать?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Is the screen white or is it black?
The screen is black
Экран является чёрным
Does this happen with regular calls or through loudspeaker, if the former then that's how it's supposed to work, if the later try the following.
Does your phone has a protective case, film and/or glass? if it does, remove it then clean the screen, if it doesn't clean the screen.
then test the proximity sensor.
Settings > About phone > Diagnostics > Test
Oreo
Settings > Support > Tests
